you might as well check all the connectors you can find/get to, its not that difficult and once cleaned if it's still bad you'll know the problem isn't that. corroded connectors can cause all kinds of issues. get the Timing checked again.
Not that I think it’s causing the misfire but I'd also do a vac/boost check (you can make a plug yourself cheap) see tech section.
